Ana içeriğe geç
Shark Steam Pocket Mop Water Tank / Bladder Replacement
Neye ihtiyacın var
  1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: adım 1, 3 resimden 1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: adım 1, 3 resimden 2. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: adım 1, 3 resimden 3.
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: adım 2, 2 resimden 1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: adım 2, 2 resimden 2.
    • Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
  3. Shark Steam Pocket Mop Water Tank / Bladder Replacement: adım 3, 3 resimden 1. Shark Steam Pocket Mop Water Tank / Bladder Replacement: adım 3, 3 resimden 2. Shark Steam Pocket Mop Water Tank / Bladder Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
    • Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
    • To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
Sonuç
Jacob Howe
549 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 642
