Ana içeriğe geç
Shark Ultimate Professional Circuit Board Replacement
Neye ihtiyacın var
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 2. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 3.
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Circuit Board Replacement: adım 2, 2 resimden 1. Shark Ultimate Professional Circuit Board Replacement: adım 2, 2 resimden 2.
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Circuit Board Replacement: adım 3, 1 resimden 1.
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
  4. Shark Ultimate Professional Circuit Board Replacement: adım 4, 3 resimden 1. Shark Ultimate Professional Circuit Board Replacement: adım 4, 3 resimden 2. Shark Ultimate Professional Circuit Board Replacement: adım 4, 3 resimden 3.
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Circuit Board Replacement: adım 5, 2 resimden 1. Shark Ultimate Professional Circuit Board Replacement: adım 5, 2 resimden 2.
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
  6. Shark Ultimate Professional Circuit Board Replacement: adım 6, 2 resimden 1. Shark Ultimate Professional Circuit Board Replacement: adım 6, 2 resimden 2.
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
  7. Shark Ultimate Professional Circuit Board Replacement: adım 7, 3 resimden 1. Shark Ultimate Professional Circuit Board Replacement: adım 7, 3 resimden 2. Shark Ultimate Professional Circuit Board Replacement: adım 7, 3 resimden 3.
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
  8. Shark Ultimate Professional Circuit Board Replacement: adım 8, 1 resimden 1.
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Drew Carff
868 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G4
3 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - Yanıt
where do I buy it's circuit board?
egovieira - Yanıt
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - Yanıt
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 3,203
