Ana içeriğe geç
Shark Ultimate Professional Heat Plate Replacement
Neye ihtiyacın var
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: adım 1, 3 resimden 1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: adım 1, 3 resimden 2. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: adım 1, 3 resimden 3.
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Heat Plate Replacement: adım 2, 2 resimden 1. Shark Ultimate Professional Heat Plate Replacement: adım 2, 2 resimden 2.
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Heat Plate Replacement: adım 3, 1 resimden 1.
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Heat Plate Replacement: adım 4, 3 resimden 1. Shark Ultimate Professional Heat Plate Replacement: adım 4, 3 resimden 2. Shark Ultimate Professional Heat Plate Replacement: adım 4, 3 resimden 3.
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Heat Plate Replacement: adım 5, 2 resimden 1. Shark Ultimate Professional Heat Plate Replacement: adım 5, 2 resimden 2.
    • Remove two screws (left and right) affixed to circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Drew Carff
868 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G4
3 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - Yanıt
Where is the part about the heat plate?
Nealy Moxam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 2,257
