Ana içeriğe geç
Shark Ultimate Professional Power Cord Replacement
Neye ihtiyacın var
    1. Shark Ultimate Professional Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Shark Ultimate Professional Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Shark Ultimate Professional Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
      • Use a Phillips #0 screwdriver to remove the two 11.5mm screws on the back of the iron.
      • Remove the back cover piece.
      • Make sure iron is unplugged and cooled off.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Ultimate Professional Power Cord Replacement: adım 2, 2 resimden 1. Shark Ultimate Professional Power Cord Replacement: adım 2, 2 resimden 2.
      • Use a Phillips #0 screwdriver to remove the two 11.8mm screws holding the white clamp to the iron.
      • Use the Phillips #0 screwdriver to remove the two 6.6mm screws holding the black wires to the body of the iron.
      • Removing the left black wire will also free the red wire, attached by the same screw.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Ultimate Professional Power Cord Replacement: adım 3, 3 resimden 1. Shark Ultimate Professional Power Cord Replacement: adım 3, 3 resimden 2. Shark Ultimate Professional Power Cord Replacement: adım 3, 3 resimden 3.
      • Pull the split end of the power cord upward through the ball joint of the iron.
      • Pull the rubber stopper through the split end of the wire.
      • Pull the wire through the plastic cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Drew Carff
880 İtibar
5 adet Kılavuz yazıldı
6Kılavuz Yorumları
Where can you get a replacement power cord?
dnojokes - Yanıt Paylaş
Yes, where can we get cords? I see a lot of people having trouble with shark irons
Betty Gulley - Yanıt Paylaş
These instructions are not helpful at all without a source to purchase a replacement cable. Two people have previously asked this question. Can we get a response? I have done extensive searches online for a POLARIZED 16/2 HPN power cable with crimped ring terminals. NON-polarized ones are cheap and readily available. The show up immediately when searching for an iron replacement power cable. That’s not the cable used for this iron, nor is it the cable used in the pictures of this repair. Please tell us where we can purchase the cable, or even tell us you don’t know. Please, don’t just ignore the inquiry.
MDGadget - Yanıt Paylaş
Model# GI505-55 uses security T-10 screw used to secure back panel. Suggest testing both conductors for continuity from above white clamp to the ring connectors. This may be the point of failure if the clamp was over-tightened. In this case, the cord can be reused with a loss of 6 inches and crimping of new ring connectors.
Andrew Shamis - Yanıt Paylaş
Thank you Andrew!
Ferdinant - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 108
Her zaman: 10,359
