Giriş
Replacing the battery on your Shark Vertex Pro (model IZ682H) is required from time to time, as the battery is what provides power to the vacuum. Without a charged, working battery, the shark will not function.
Before using this guide, please look over the battery and verify it is not damaged or corroding. A damaged or corroded battery needs to be disposed of safely and a new battery must be obtained.
This manual illustrates the removal of the battery for charging, or replacement if it is no longer accepting a charge.
On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
