Ana içeriğe geç
Sharp Aquos Crystal Battery Replacement
Neye ihtiyacın var
    1. Sharp Aquos Crystal Battery Replacement, Back Panel: adım 1, 3 resimden 1. Sharp Aquos Crystal Battery Replacement, Back Panel: adım 1, 3 resimden 2. Sharp Aquos Crystal Battery Replacement, Back Panel: adım 1, 3 resimden 3.
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Sharp Aquos Crystal Battery Replacement, USB Port: adım 2, 2 resimden 1. Sharp Aquos Crystal Battery Replacement, USB Port: adım 2, 2 resimden 2.
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sharp Aquos Crystal Battery Replacement: adım 3, 2 resimden 1. Sharp Aquos Crystal Battery Replacement: adım 3, 2 resimden 2.
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      FixBot'a Sor
      Yorum Ekle
    3. Sharp Aquos Crystal Battery Replacement: adım 4, 2 resimden 1. Sharp Aquos Crystal Battery Replacement: adım 4, 2 resimden 2.
      • Disconnect the wire by lifting it up with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Sharp Aquos Crystal Battery Replacement: adım 5, 3 resimden 1. Sharp Aquos Crystal Battery Replacement: adım 5, 3 resimden 2. Sharp Aquos Crystal Battery Replacement: adım 5, 3 resimden 3.
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      FixBot'a Sor
      Yorum Ekle
    5. Sharp Aquos Crystal Battery Replacement: adım 6, 1 resimden 1.
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      FixBot'a Sor
      Yorum Ekle
    1. Sharp Aquos Crystal Battery Replacement, Motherboard: adım 7, 1 resimden 1.
      • Peel off the black pieces of tape.
      FixBot'a Sor
      Yorum Ekle
    2. Sharp Aquos Crystal Battery Replacement: adım 8, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Sharp Aquos Crystal Battery Replacement: adım 9, 2 resimden 1. Sharp Aquos Crystal Battery Replacement: adım 9, 2 resimden 2.
      • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
      FixBot'a Sor
      Yorum Ekle
    4. Sharp Aquos Crystal Battery Replacement: adım 10, 1 resimden 1.
      • Peel the tape off with your hands.
      FixBot'a Sor
      Yorum Ekle
    5. Sharp Aquos Crystal Battery Replacement: adım 11, 1 resimden 1.
      • Lift the motherboard out with your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Sharp Aquos Crystal Battery Replacement, Battery: adım 12, 1 resimden 1.
      • Peel off the tape holding the battery down.
      FixBot'a Sor
      Yorum Ekle
    2. Sharp Aquos Crystal Battery Replacement: adım 13, 2 resimden 1. Sharp Aquos Crystal Battery Replacement: adım 13, 2 resimden 2.
      • Lift the battery out with your hands.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Felicia Imbriano
1.266 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G4
3 Üyeler
40 adet Kılavuz yazıldı
3Kılavuz Yorumları
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - Yanıt Paylaş
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - Yanıt Paylaş
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 92
Her zaman: 19,040
