Ana içeriğe geç
Sharp Aquos Crystal USB Port Replacement
Neye ihtiyacın var
    1. Sharp Aquos Crystal USB Port Replacement, Back Panel: adım 1, 3 resimden 1. Sharp Aquos Crystal USB Port Replacement, Back Panel: adım 1, 3 resimden 2. Sharp Aquos Crystal USB Port Replacement, Back Panel: adım 1, 3 resimden 3.
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Sharp Aquos Crystal USB Port Replacement, USB Port: adım 2, 2 resimden 1. Sharp Aquos Crystal USB Port Replacement, USB Port: adım 2, 2 resimden 2.
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sharp Aquos Crystal USB Port Replacement: adım 3, 2 resimden 1. Sharp Aquos Crystal USB Port Replacement: adım 3, 2 resimden 2.
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      FixBot'a Sor
      Yorum Ekle
    3. Sharp Aquos Crystal USB Port Replacement: adım 4, 2 resimden 1. Sharp Aquos Crystal USB Port Replacement: adım 4, 2 resimden 2.
      • Disconnect the wire by lifting it up with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Sharp Aquos Crystal USB Port Replacement: adım 5, 3 resimden 1. Sharp Aquos Crystal USB Port Replacement: adım 5, 3 resimden 2. Sharp Aquos Crystal USB Port Replacement: adım 5, 3 resimden 3.
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      FixBot'a Sor
      Yorum Ekle
    5. Sharp Aquos Crystal USB Port Replacement: adım 6, 1 resimden 1.
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Felicia Imbriano
1.266 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Catania Spring 2016 UMass Dartmouth, Team 7-4, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G4
3 Üyeler
40 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 3,055
