Ana içeriğe geç
Sharp Aquos LC13B2UA Back Case Replacement
Neye ihtiyacın var
  1. Sharp Aquos LC13B2UA Back Case Replacement, Stand: adım 1, 2 resimden 1. Sharp Aquos LC13B2UA Back Case Replacement, Stand: adım 1, 2 resimden 2.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Back Case Replacement: adım 2, 2 resimden 1. Sharp Aquos LC13B2UA Back Case Replacement: adım 2, 2 resimden 2.
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: adım 3, 3 resimden 1. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: adım 3, 3 resimden 2. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: adım 3, 3 resimden 3.
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Back Case Replacement: adım 4, 2 resimden 1. Sharp Aquos LC13B2UA Back Case Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Back Case Replacement: adım 5, 1 resimden 1.
    • Using your hands, gently lift and remove the back case of the television.
Sonuç
Robert Hobson
1.290 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G11
4 Üyeler
Bir Yorum
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 4,106
