Giriş
Outline what you are going to teach someone how to do.
Parçalar
Hiçbir parçaya gerek yok.
  1. Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television.
    • Lift the stand off the television.
    • Remove the two back panels to display the audio and video inputs..
    • Remove the eight 6mm Phillips screws around the edge.
    • Remove the two 6mm Phillips near the inputs.
    • Lift and remove the back case of the television.
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
    • Remove the eight 10mm screws connecting the two speakers to the front case.
    • Remove the two black tape strips securing the audio cables to the case.
    • Lift the audio cable from the plastic prongs securing it to the front case
    • The speakers can now be removed.
    • To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws.
    • Lift the circuit to remove the plastic LED casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Hobson
1.275 İtibar
9 adet Kılavuz yazıldı
Takım
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G11
4 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 17
Her zaman: 2,535
