Giriş
Outline what you are going to teach someone how to do.
Neye ihtiyacın var
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
Remove the two 6mm Phillips screws.
Pull the board toward you, giving you access to the power button.
Unscrew the two 4mm Phillips screws.
Lift the buttons off the front case.
Remove the eight 10mm screws connecting the two speakers to the front case.
Bir başkası bu kılavuzu tamamladı.
