Ana içeriğe geç
Sharp Aquos LC13B2UA Power Button Replacement
Neye ihtiyacın var
  1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: adım 1, 2 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: adım 1, 2 resimden 2.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Power Button Replacement: adım 2, 2 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement: adım 2, 2 resimden 2.
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: adım 3, 3 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: adım 3, 3 resimden 2. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: adım 3, 3 resimden 3.
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Power Button Replacement: adım 4, 2 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Power Button Replacement: adım 5, 1 resimden 1.
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: adım 6, 3 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: adım 6, 3 resimden 2. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Power Button Replacement: adım 7, 2 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement: adım 7, 2 resimden 2.
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Power Button Replacement: adım 8, 2 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement: adım 8, 2 resimden 2.
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Power Button Replacement: adım 9, 1 resimden 1.
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: adım 10, 3 resimden 1. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: adım 10, 3 resimden 2. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: adım 10, 3 resimden 3.
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
Sonuç
Robert Hobson
1.290 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-11, Amido Winter 2011 Cal Poly, Team 1-11, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G11
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 16
Her zaman: 6,518
