Ana içeriğe geç
Sharp EL-510RN Calculator Battery Replacement
Neye ihtiyacın var
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: adım 1, 2 resimden 1. Sharp EL-510RN Calculator Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: adım 2, 3 resimden 1. Sharp EL-510RN Calculator Battery Replacement: adım 2, 3 resimden 2. Sharp EL-510RN Calculator Battery Replacement: adım 2, 3 resimden 3.
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: adım 3, 3 resimden 1. Sharp EL-510RN Calculator Battery Replacement: adım 3, 3 resimden 2. Sharp EL-510RN Calculator Battery Replacement: adım 3, 3 resimden 3.
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: adım 4, 3 resimden 1. Sharp EL-510RN Calculator Battery Replacement: adım 4, 3 resimden 2. Sharp EL-510RN Calculator Battery Replacement: adım 4, 3 resimden 3.
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: adım 5, 1 resimden 1.
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Sonuç
Harish Kugathasalingam
121 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 4-5, Allen Fall 2022 York University, Team 4-5, Allen Fall 2022 üyesi
YORK-ALLEN-F22S4G5
2 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 36
Her zaman: 545
