Ana içeriğe geç
Sharp EL-520X Loose Circuit Board Wire Fix
Neye ihtiyacın var
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: adım 1, 1 resimden 1.
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: adım 2, 2 resimden 1. Sharp EL-520X Loose Circuit Board Wire Fix: adım 2, 2 resimden 2.
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: adım 3, 1 resimden 1.
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: adım 4, 1 resimden 1.
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: adım 5, 1 resimden 1.
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: adım 6, 1 resimden 1.
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: adım 7, 3 resimden 1. Sharp EL-520X Loose Circuit Board Wire Fix: adım 7, 3 resimden 2. Sharp EL-520X Loose Circuit Board Wire Fix: adım 7, 3 resimden 3.
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Mohamad Mohamad
484 İtibar
3 adet Kılavuz yazıldı
Ekip
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 üyesi
YORK-ALLEN-SU23SMG6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 593
