Ana içeriğe geç
Sharp FX Digitizer/Screen Replacement
Neye ihtiyacın var
    1. Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: adım 1, 3 resimden 1. Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: adım 1, 3 resimden 2. Sharp FX Digitizer/Screen Replacement, Digitizer/Screen: adım 1, 3 resimden 3.
      • Remove - Back,microSD,battery,sim
      • Remove black rubber screw covers on back of display.
      • Remove 000 phillips screws (4) from top of display.
      FixBot'a Sor
      Yorum Ekle
    2. Sharp FX Digitizer/Screen Replacement: adım 2, 2 resimden 1. Sharp FX Digitizer/Screen Replacement: adım 2, 2 resimden 2.
      • Remove 3 small silver screws from battery area.
      • Remove 2 Torx t-7's by MicroSD slot.
      • After screws are removed you can detach screen.
      FixBot'a Sor
      Yorum Ekle
    3. Sharp FX Digitizer/Screen Replacement: adım 3, 3 resimden 1. Sharp FX Digitizer/Screen Replacement: adım 3, 3 resimden 2. Sharp FX Digitizer/Screen Replacement: adım 3, 3 resimden 3.
      • Remove 4 additional 000 phillips screws from display.
      • Using some heat,spudger,frce pry away the broken display from the frame.
      • Use extreme caution the actual display is very fragile.
      FixBot'a Sor
      Yorum Ekle
    4. Sharp FX Digitizer/Screen Replacement: adım 4, 3 resimden 1. Sharp FX Digitizer/Screen Replacement: adım 4, 3 resimden 2. Sharp FX Digitizer/Screen Replacement: adım 4, 3 resimden 3.
      • Remove connector for digitizer
      • replace connector with new digitizer and rebuild.
      FixBot'a Sor
      Yorum Ekle
    5. Sharp FX Digitizer/Screen Replacement: adım 5, 3 resimden 1. Sharp FX Digitizer/Screen Replacement: adım 5, 3 resimden 2. Sharp FX Digitizer/Screen Replacement: adım 5, 3 resimden 3.
      • Reconnect to main motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Sharp FX Digitizer/Screen Replacement: adım 6, 3 resimden 1. Sharp FX Digitizer/Screen Replacement: adım 6, 3 resimden 2. Sharp FX Digitizer/Screen Replacement: adım 6, 3 resimden 3.
      • reassemble.
      • Enjoy the new display
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
jckoniecki
51 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 3,659
