Ana içeriğe geç
Sharp-EL-531xg Battery Replacement
Neye ihtiyacın var
  1. Sharp-EL-531xg Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: adım 2, 2 resimden 1. Sharp-EL-531xg Battery Replacement: adım 2, 2 resimden 2.
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: adım 3, 1 resimden 1.
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: adım 4, 3 resimden 1. Sharp-EL-531xg Battery Replacement: adım 4, 3 resimden 2. Sharp-EL-531xg Battery Replacement: adım 4, 3 resimden 3.
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: adım 5, 1 resimden 1.
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: adım 6, 1 resimden 1.
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: adım 7, 2 resimden 1. Sharp-EL-531xg Battery Replacement: adım 7, 2 resimden 2.
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 1,278
