Ana içeriğe geç
Sharper Image SVC430 Lens Replacement
Neye ihtiyacın var
  1. Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: adım 1, 2 resimden 1. Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: adım 1, 2 resimden 2.
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Lens Replacement: adım 2, 2 resimden 1. Sharper Image SVC430 Lens Replacement: adım 2, 2 resimden 2.
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Lens Replacement: adım 3, 3 resimden 1. Sharper Image SVC430 Lens Replacement: adım 3, 3 resimden 2. Sharper Image SVC430 Lens Replacement: adım 3, 3 resimden 3.
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Lens Replacement: adım 4, 2 resimden 1. Sharper Image SVC430 Lens Replacement: adım 4, 2 resimden 2.
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Lens Replacement: adım 5, 1 resimden 1.
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Lens Replacement: adım 6, 3 resimden 1. Sharper Image SVC430 Lens Replacement: adım 6, 3 resimden 2. Sharper Image SVC430 Lens Replacement: adım 6, 3 resimden 3.
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Lens Replacement: adım 7, 1 resimden 1.
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Lens Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Lens Replacement: adım 9, 1 resimden 1.
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Lens Replacement: adım 10, 1 resimden 1.
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Lens Replacement, Lens: adım 11, 1 resimden 1.
    • Behind the lens, use the metal screwdriver to unscrew the two screws holding the lens in place on the circuit board.
  12. Sharper Image SVC430 Lens Replacement: adım 12, 1 resimden 1.
    • The lens should easily remove from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 198
