Ana içeriğe geç
Shenzhou k680e Silicone Grease Replacement
Neye ihtiyacın var
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: adım 1, 1 resimden 1.
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: adım 2, 1 resimden 1.
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: adım 3, 1 resimden 1.
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: adım 4, 1 resimden 1.
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: adım 5, 1 resimden 1.
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: adım 6, 1 resimden 1.
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: adım 7, 1 resimden 1.
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: adım 8, 1 resimden 1.
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: adım 9, 2 resimden 1. Shenzhou k680e Silicone Grease Replacement: adım 9, 2 resimden 2.
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: adım 10, 1 resimden 1.
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: adım 11, 1 resimden 1.
    • Squeeze new thermal paste onto the chips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yizhen Qu
217 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 654
