Ana içeriğe geç
Shimano Ultegra 6800 Caliper Brake Maintenance
Neye ihtiyacın var
  1. Shimano Ultegra 6800 Caliper Brake Maintenance, Shimano Ultegra 6800 Caliper Brake Maintenance: adım 1, 1 resimden 1.
    • Using the 5mm allen wrench,check if the bolt on the backside of the caliper is snug.
  2. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 2, 1 resimden 1.
    • If your brake caliper is still tightened, loosen the cable bolt with a 5mm Allen wrench to take tension off the caliper.
  3. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 3, 3 resimden 1. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 3, 3 resimden 2. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 3, 3 resimden 3.
    • Check if the braking pads are contacting the rim in desired locations.
    • Both pads are loosened the same way.
    • For the left caliper pad, marked in the red circle, loosen the bolt with a 4mm Allen wrench so the pad can be adjusted.
    • Align the bottom edge of the pad with the bottom edge of the braking surface and then tighten.
    • For the right caliper pad, marked in the yellow circle, loosen the bolt with a 4mm Allen wrench so the pad can be adjusted.
    • Align the top edge of the pad with the top edge of the braking surface and then tighten.
  4. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 4, 1 resimden 1.
    • Check if your brake cable is inside the groove on the two plates (marked in the red cirlce) that hold the brake cable.
  5. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 5, 2 resimden 1. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 5, 2 resimden 2.
    • If the adjustment lever is not turned down, turn it down.
  6. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 6, 2 resimden 1. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 6, 2 resimden 2.
    • Squeeze the caliper until both sides are about 1mm from the rim.
    • While still squeezing, pull down the slack on the wire and tension the wire by bolting it down.
  7. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 7, 1 resimden 1.
    • Fine tune the brake calipers by using the barrel adjuster.
    • Counter clockwise turns open the calipers and clockwise turns close the calipers.
  8. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 8, 1 resimden 1.
    • Make the brake pads equidistant from the rim by adjusting the tiny bolt on top of the caliper with a 3mm Allen wrench.
  9. Shimano Ultegra 6800 Caliper Brake Maintenance: adım 9, 1 resimden 1.
    • Check if the brakes are working properly by squeezing your brake levers.
Sonuç
Check if your brakes are properly working before you ride. If the tightness and alignment are satisfactory, enjoy your ride.
7 farklı kişi bu kılavuzu tamamladı.
Leland Lam
348 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-4, Green Winter 2015 Cal Poly, Team 24-4, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G4
4 Üyeler
3 adet Kılavuz yazıldı
5 Yorum
There is a second small adjusting screw further in on the caliper, pushing against the spring. I think I know what it’s for, but why not point that out, lest someone use it mistakenly. So?
David Kuch - Yanıt
What is the purpose of having the pads offset where one is lined up to the bottom of the rim and one lined up to the top as shown on Step #3 above in comparison to just having the pad surface completely the same?
spicedupflip - Yanıt
This is not needed on ultegra callipers as they are duel symmetric and both pads move up on braking. Pads should be set to the lower area of the rim. Duel pivot callipers need the above setting.
jeremy isaacs -
How do you make dual symmetric Ultegra calipers centred as they do not have the bolt in step 8?
Damon Murphy - Yanıt
Park tools has a great video on adjusting the calipers and addresses all types of calipers and explains how to adjust and center the pads.
https://www.youtube.com/watch?v=q4ay12CS...
lmi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 34
Son 30 gün: 134
Her zaman: 31,826
