Ana içeriğe geç
Shoe Buckle Replacement
Neye ihtiyacın var
  1. Shoe Buckle Replacement, Shoe Buckle: adım 1, 3 resimden 1. Shoe Buckle Replacement, Shoe Buckle: adım 1, 3 resimden 2. Shoe Buckle Replacement, Shoe Buckle: adım 1, 3 resimden 3.
    • Begin by opening the buckle on the shoe you want to change.
  2. Shoe Buckle Replacement: adım 2, 3 resimden 1. Shoe Buckle Replacement: adım 2, 3 resimden 2. Shoe Buckle Replacement: adım 2, 3 resimden 3.
    • Examine the back of the strap to locate the seam.
    • Gently unthread the stitches from the back, and work your way to the front with the seam ripper.
  3. Shoe Buckle Replacement: adım 3, 3 resimden 1. Shoe Buckle Replacement: adım 3, 3 resimden 2. Shoe Buckle Replacement: adım 3, 3 resimden 3.
    • Now, open up the strap attached to the old buckle and slide it off.
  4. Shoe Buckle Replacement: adım 4, 3 resimden 1. Shoe Buckle Replacement: adım 4, 3 resimden 2. Shoe Buckle Replacement: adım 4, 3 resimden 3.
    • Put your new buckle back onto the strap you just unstitched.
  5. Shoe Buckle Replacement: adım 5, 3 resimden 1. Shoe Buckle Replacement: adım 5, 3 resimden 2. Shoe Buckle Replacement: adım 5, 3 resimden 3.
    • Let's begin with the threading process.
    • To begin, thread the needle by passing the thread through its eye.
    • Then, align the unstitched strap with the old stitching onto the shoe, as this will act as your guide.
  6. Shoe Buckle Replacement: adım 6, 3 resimden 1. Shoe Buckle Replacement: adım 6, 3 resimden 2. Shoe Buckle Replacement: adım 6, 3 resimden 3.
    • Once it's aligned, use the previous stitching holes as a guide to begin stitching.
    • After completing the process, proceed to tie the thread.
  7. Shoe Buckle Replacement: adım 7, 2 resimden 1. Shoe Buckle Replacement: adım 7, 2 resimden 2.
    • Finally, use the seam ripper to cut off the remaining thread.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alyssa Tu
145 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 114
Her zaman: 1,926
