Ana içeriğe geç
Shoe Insole Repair
Neye ihtiyacın var
    1. Shoe Insole Repair, Shoe Insole Repair: adım 1, 1 resimden 1.
      • Collect everything you need for the repair.
      • A piece of foam from new shoe packaging is ideal because it matches the insole’s cushioning. If you don’t have foam, a thick old sock or piece of soft clothing works well too.
      FixBot'a Sor
      Yorum Ekle
    2. Shoe Insole Repair: adım 2, 2 resimden 1. Shoe Insole Repair: adım 2, 2 resimden 2.
      • Place your insole on a flat surface. Use a marker or pen to trace the outline of the hole (or worn spot) onto your scrap foam or fabric.
      • Trace slightly larger than the hole so the patch overlaps the edges a little for a stronger repair.
      FixBot'a Sor
      Yorum Ekle
    3. Shoe Insole Repair: adım 3, 3 resimden 1. Shoe Insole Repair: adım 3, 3 resimden 2. Shoe Insole Repair: adım 3, 3 resimden 3.
      • Carefully cut along your traced line with scissors. Test the patch in the hole; it should sit flush or slightly above the insole. Trim as needed until it fits snugly without gaps.
      • If the hole goes all the way through the insole, cut a second identical patch to layer underneath for extra support.
      FixBot'a Sor
      Yorum Ekle
    4. Shoe Insole Repair: adım 4, 3 resimden 1. Shoe Insole Repair: adım 4, 3 resimden 2. Shoe Insole Repair: adım 4, 3 resimden 3.
      • Apply a thin layer of glue all around the edges of the patch. Press it firmly into the hole so the glue makes good contact with the surrounding insole. Use small pieces of tape to hold the patch securely while the glue dries.
      • Usually 10–30 minutes, or follow your glue’s drying instructions).
      FixBot'a Sor
      Yorum Ekle
    5. Shoe Insole Repair: adım 5, 2 resimden 1. Shoe Insole Repair: adım 5, 2 resimden 2.
      • Once the glue is fully dry, remove the tape. Press on the patch and test how it feels.
      • If it’s loose or there are gaps, apply a bit more glue around the edges and tape it down again to dry.
      FixBot'a Sor
      Yorum Ekle
    6. Shoe Insole Repair: adım 6, 1 resimden 1.
      • This step is optional. For a longer-lasting and more comfortable repair, cut a thin piece of fabric (from an old sock or t-shirt) slightly larger than the patch. Apply glue to the back of the fabric and press it smoothly over the repaired area. This creates a softer surface for your foot and helps the patch hold up better over time.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Claire Vest
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 44
Son 30 gün: 184
Her zaman: 508
