Ana içeriğe geç
Shop-Vac MC150A Filter Cage Replacement
Neye ihtiyacın var
  1. Shop-Vac MC150A Filter Cage Replacement, Unlatch the power unit assembly: adım 1, 1 resimden 1.
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Filter Cage Replacement, Remove the foam sleeve: adım 2, 1 resimden 1.
    • Slide the foam sleeve up from the filter cage to remove it.
  3. Shop-Vac MC150A Filter Cage Replacement, Unscrew the filter cage: adım 3, 1 resimden 1.
    • Use a 3.5 mm hex key to remove the two screws securing the filter cage.
  4. Shop-Vac MC150A Filter Cage Replacement, Remove the filter cage: adım 4, 1 resimden 1.
    • Remove the filter cage.
Sonuç
Ngunlian
732 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G2
5 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 36
Her zaman: 1,761
