Ana içeriğe geç
Shop-Vac MC150A Motor Replacement
Neye ihtiyacın var
    1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: adım 1, 1 resimden 1.
      • Before you begin, make sure to switch off the device and unplug it from the outlet.
      • Unlatch the two side clips securing the power unit assembly to the tank.
      • Remove the power unit assembly from the tank assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Shop-Vac MC150A Motor Replacement, Remove the top cover: adım 2, 2 resimden 1. Shop-Vac MC150A Motor Replacement, Remove the top cover: adım 2, 2 resimden 2.
      • Use a 3.5 mm hex key to remove the three screws securing the top cover.
      • Remove the top cover.
      FixBot'a Sor
      Yorum Ekle
    3. Shop-Vac MC150A Motor Replacement: adım 3, 1 resimden 1.
      • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
      FixBot'a Sor
      Yorum Ekle
    4. Shop-Vac MC150A Motor Replacement: adım 4, 1 resimden 1.
      • Separate the power unit assembly from the cover.
      FixBot'a Sor
      Yorum Ekle
    1. Shop-Vac MC150A Motor Replacement, Disconnect the switch: adım 5, 3 resimden 1. Shop-Vac MC150A Motor Replacement, Disconnect the switch: adım 5, 3 resimden 2. Shop-Vac MC150A Motor Replacement, Disconnect the switch: adım 5, 3 resimden 3.
      • Pull out and disconnect the four spade connectors from the switch module.
      • During reassembly, use the last image as a reference for how to connect the wires.
      FixBot'a Sor
      Yorum Ekle
    2. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: adım 6, 2 resimden 1. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: adım 6, 2 resimden 2.
      • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
      FixBot'a Sor
      Yorum Ekle
    3. Shop-Vac MC150A Motor Replacement: adım 7, 2 resimden 1. Shop-Vac MC150A Motor Replacement: adım 7, 2 resimden 2.
      • During reassembly, be sure to reattach the green ground wire clip to the bracket.
      FixBot'a Sor
      Yorum Ekle
    4. Shop-Vac MC150A Motor Replacement: adım 8, 1 resimden 1.
      • Separate the clip from the green wire and transfer it to the replacement motor.
      FixBot'a Sor
      Yorum Ekle
    1. Shop-Vac MC150A Motor Replacement, Motor: adım 9, 2 resimden 1. Shop-Vac MC150A Motor Replacement, Motor: adım 9, 2 resimden 2.
      • Remove the motor bracket.
      FixBot'a Sor
      Yorum Ekle
    2. Shop-Vac MC150A Motor Replacement: adım 10, 1 resimden 1.
      • Turn the part over to the other side.
      • Use the socket wrench remove the bolt securing the aluminum plate.
      FixBot'a Sor
      Yorum Ekle
    3. Shop-Vac MC150A Motor Replacement: adım 11, 1 resimden 1.
      • Unscrew the two Phillips head screws holding the cover to the motor.
      • After removing the cover to the motor, you can replace the motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ngunlian
756 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G2
5 Üyeler
30 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do I buy a new motor?????
Gerald Mikel - Yanıt Paylaş
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 41
Son 30 gün: 205
Her zaman: 32,474
