Ana içeriğe geç
Shop-Vac MC150A Power Switch Replacement
Neye ihtiyacın var
    1. Shop-Vac MC150A Power Switch Replacement, Unlatch the power unit assembly: adım 1, 1 resimden 1.
      • Before you begin, make sure to switch off the device and unplug it from the outlet.
      • Unlatch the two side clips securing the power unit assembly to the tank.
      • Remove the power unit assembly from the tank assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: adım 2, 2 resimden 1. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: adım 2, 2 resimden 2.
      • Use a 3.5 mm hex key to remove the three screws securing the top cover.
      • Remove the top cover.
      FixBot'a Sor
      Yorum Ekle
    3. Shop-Vac MC150A Power Switch Replacement: adım 3, 1 resimden 1.
      • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
      FixBot'a Sor
      Yorum Ekle
    4. Shop-Vac MC150A Power Switch Replacement: adım 4, 1 resimden 1.
      • Separate the power unit assembly from the cover.
      FixBot'a Sor
      Yorum Ekle
    1. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: adım 5, 3 resimden 1. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: adım 5, 3 resimden 2. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: adım 5, 3 resimden 3.
      • Pull out and disconnect the four spade connectors from the switch module.
      • During reassembly, use the last image as a reference for how to connect the wires.
      FixBot'a Sor
      Yorum Ekle
    2. Shop-Vac MC150A Power Switch Replacement: adım 6, 1 resimden 1.
      • Use a spudger to pry up and remove the red switch from the housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ngunlian
756 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G2
5 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 105
Her zaman: 18,611
