Ana içeriğe geç
Shop-Vac MC150A Power Unit Assembly Replacement
Neye ihtiyacın var
  1. Shop-Vac MC150A Power Unit Assembly Replacement, Unlatch the power unit assembly: adım 1, 1 resimden 1.
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Unit Assembly Replacement, Remove the top cover: adım 2, 2 resimden 1. Shop-Vac MC150A Power Unit Assembly Replacement, Remove the top cover: adım 2, 2 resimden 2.
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Unit Assembly Replacement: adım 3, 1 resimden 1.
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Unit Assembly Replacement: adım 4, 1 resimden 1.
    • Separate the power unit assembly from the cover.
Sonuç
Ngunlian
732 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G2
5 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 1,217
