Ana içeriğe geç
Shower Glass Silicone Replacement
Neye ihtiyacın var
  1. Shower Glass Silicone Replacement, Shower Glass Silicone Replacement: adım 1, 1 resimden 1.
    • Make sure the area is dry and clean.
  2. Shower Glass Silicone Replacement: adım 2, 3 resimden 1. Shower Glass Silicone Replacement: adım 2, 3 resimden 2. Shower Glass Silicone Replacement: adım 2, 3 resimden 3.
    • Adjust the utility knife to a length of about 1 cm, or the width of the old silicone.
    • Cut at the top and bottom of the silicone (close to the glass and bathtub), all the way down to the end. Do not push past the adjusted knife length.
  3. Shower Glass Silicone Replacement: adım 3, 3 resimden 1. Shower Glass Silicone Replacement: adım 3, 3 resimden 2. Shower Glass Silicone Replacement: adım 3, 3 resimden 3.
    • Use a putty knife to separate the silicone from the bathtub and from the glass sides.
    • Pull the old silicone with your hand while using the putty knife to separate the silicone.
  4. Shower Glass Silicone Replacement: adım 4, 3 resimden 1. Shower Glass Silicone Replacement: adım 4, 3 resimden 2. Shower Glass Silicone Replacement: adım 4, 3 resimden 3.
    • Use a utility knife to remove any large sticking mold or silicone parts still left.
    • Use a fine grit sand paper to take off the small parts of the old silicone.
    • Vacuum away all the debris.
    • Be very precise and take your time with the knife.
  5. Shower Glass Silicone Replacement: adım 5, 3 resimden 1. Shower Glass Silicone Replacement: adım 5, 3 resimden 2. Shower Glass Silicone Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Clean the area with a mold cleaner so that small matter, and particles can be removed. Spray the cleaner, wait about 15 minutes, scrub, and wash thoroughly until all the chemical is gone.
    • Wear gloves if using cleaner that has bleach or strong chemicals.
    • Now wipe the area clean with a microfiber cloth, until it is dry.
  6. Shower Glass Silicone Replacement: adım 6, 3 resimden 1. Shower Glass Silicone Replacement: adım 6, 3 resimden 2. Shower Glass Silicone Replacement: adım 6, 3 resimden 3.
    • Wait until the area is completely dry, which may also done by continuously wiping with a dry cloth.
    • Use painters tape to mask off both ends of the joint, at about a centimeter above and to the side of the tub.
  7. Shower Glass Silicone Replacement: adım 7, 3 resimden 1. Shower Glass Silicone Replacement: adım 7, 3 resimden 2. Shower Glass Silicone Replacement: adım 7, 3 resimden 3.
    • Place the new tube of silicone in the gun, and cut off about a half inch off of the tip. Poke the hole from the tip of the new silicone, with the accessory on the caulking gun.
    • Press slowly until the glue comes out slightly. Start from one end and press into the crack as you run the silicone to the other end in one motion. Use an amount of glue so that it comes out slightly at the corners that you're caulking.
    • Make sure to put enough glue and not too little, as you will need to run your finger down the glue in one motion to smooth it out. Run your finger only once.
    • Wait about 10 minutes and remove the tape, so that the glue doesn't fully dry with the tape. The finish will also look cleaner when you remove the tape after caulking.
  8. Shower Glass Silicone Replacement: adım 8, 1 resimden 1.
    • Let the area to completely dry for 24 hours before touching it or using the shower. The new silicone would be now mold free.
Sonuç
Make sure to be very careful with the glass and not damage with the knife. Using the knife always be cautious and safe, wearing gloves may help.
4 farklı kişi bu kılavuzu tamamladı.
Ekip
York University, Team 1-32, O'Regan Fall 2021 York University, Team 1-32, O'Regan Fall 2021 üyesi
YORK-O'REGAN-F21S1G32
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 65
Son 30 gün: 301
Her zaman: 18,650
