Ana içeriğe geç
Shower Handle O-ring Replacement
Neye ihtiyacın var
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: adım 1, 1 resimden 1.
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: adım 2, 1 resimden 1.
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Reverse position of pliers pictured
    ajbdo1959 - Yanıt
  3. Shower Handle O-ring  Replacement: adım 3, 1 resimden 1.
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    ajbdo1959 - Yanıt
  4. Shower Handle O-ring  Replacement: adım 4, 1 resimden 1.
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: adım 5, 2 resimden 1. Shower Handle O-ring  Replacement: adım 5, 2 resimden 2.
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Cori Fitzpatrick
213 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
Rose Geiger - Yanıt
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 46
Son 30 gün: 160
Her zaman: 23,650
