Giriş
If you have a shower head with a constant drip, follow this simple and easy guide to replace the rubber o-ring in your shower handle. Replacing the O-ring can help prevent hard water build up, rusting, and wasting water.
Neye ihtiyacın var
Using your flat head screwdriver, remove the screw from the middle of the handle.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
