Ana içeriğe geç
Shure SM58 Capsule Installation Replacement
Neye ihtiyacın var
  1. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 1. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 2. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 3.
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
    FixBot'a Sor
    Yorum Ekle
  2. Shure SM58 Capsule Installation Replacement, Faceplate: adım 2, 1 resimden 1.
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    FixBot'a Sor
    Yorum Ekle
  3. Shure SM58 Capsule Installation Replacement: adım 3, 2 resimden 1. Shure SM58 Capsule Installation Replacement: adım 3, 2 resimden 2.
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  4. Shure SM58 Capsule Installation Replacement: adım 4, 2 resimden 1. Shure SM58 Capsule Installation Replacement: adım 4, 2 resimden 2.
    • Slide the face plate over the connector.
    FixBot'a Sor
    Yorum Ekle
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: adım 5, 2 resimden 1. Shure SM58 Capsule Installation Replacement, Capsule Installation: adım 5, 2 resimden 2.
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  6. Shure SM58 Capsule Installation Replacement: adım 6, 1 resimden 1.
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    FixBot'a Sor
    Yorum Ekle
  7. Shure SM58 Capsule Installation Replacement: adım 7, 1 resimden 1.
    • Slide the grille off the top of the microphone once it is all the way loosened.
    FixBot'a Sor
    Yorum Ekle
  8. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 1. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 2. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 3.
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once installed, reassemble the microphone following the steps in reverse.
9 farklı kişi bu kılavuzu tamamladı.
nat coll
859 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
47 adet Kılavuz yazıldı
5Kılavuz Yorumları
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Yanıt Paylaş
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger - Yanıt Paylaş
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Yanıt Paylaş
You can unscrew just the grill.
Burke McQuinn - Yanıt Paylaş
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 54
Son 30 gün: 243
Her zaman: 45,220
