Ana içeriğe geç
Shure SM58 Capsule Installation Replacement
Neye ihtiyacın var
  1. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 1. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 2. Shure SM58 Capsule Installation Replacement, Collar: adım 1, 3 resimden 3.
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. Shure SM58 Capsule Installation Replacement, Faceplate: adım 2, 1 resimden 1.
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    Why should I replace the plate?
    Gerrit - Yanıt
    This guide was done as part of the capsule replacement—I don’t think there is any reason to solely replace the plate unless there was corrosion on it.
    Daniel Berger - Yanıt
  3. Shure SM58 Capsule Installation Replacement: adım 3, 2 resimden 1. Shure SM58 Capsule Installation Replacement: adım 3, 2 resimden 2.
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  4. Shure SM58 Capsule Installation Replacement: adım 4, 2 resimden 1. Shure SM58 Capsule Installation Replacement: adım 4, 2 resimden 2.
    • Slide the face plate over the connector.
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: adım 5, 2 resimden 1. Shure SM58 Capsule Installation Replacement, Capsule Installation: adım 5, 2 resimden 2.
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
  6. Shure SM58 Capsule Installation Replacement: adım 6, 1 resimden 1.
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    Step 6 is incorrect. The grill screws off counter clockwise.
    Bill Kahler - Yanıt
  7. Shure SM58 Capsule Installation Replacement: adım 7, 1 resimden 1.
    • Slide the grille off the top of the microphone once it is all the way loosened.
  8. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 1. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 2. Shure SM58 Capsule Installation Replacement: adım 8, 3 resimden 3.
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    Can you replace the yellow tape/cable if broken? (seen in last pic)
    karl_ivers - Yanıt
    Honestly, I’m not sure. If I was in your position, I would assume a similarly sized piece of electrical tape should be fine, but if you’re not sure you may want to contact a repairman.
Sonuç
Once installed, reassemble the microphone following the steps in reverse.
7 farklı kişi bu kılavuzu tamamladı.
nat coll
642 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
20 adet Kılavuz yazıldı
5 Yorum
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Yanıt
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger -
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Yanıt
You can unscrew just the grill.
Burke McQuinn - Yanıt
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 52
Son 30 gün: 242
Her zaman: 39,348
