Ana içeriğe geç
Shure SM58 Faceplate Replacement
Neye ihtiyacın var
  1. Shure SM58 Faceplate Replacement, Faceplate: adım 1, 1 resimden 1.
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
  2. Shure SM58 Faceplate Replacement: adım 2, 2 resimden 1. Shure SM58 Faceplate Replacement: adım 2, 2 resimden 2.
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  3. Shure SM58 Faceplate Replacement: adım 3, 2 resimden 1. Shure SM58 Faceplate Replacement: adım 3, 2 resimden 2.
    • Slide the face plate over the connector.
Sonuç
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
nat coll
721 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 9,239
