Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The grille of the microphone is the part you speak or sing into. If it is installed and maintained properly, it will help to ensure that your microphone looks and sounds good.
  1. Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  3. Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps. Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Sonuç
Follow the steps in reverse to install the new grille on the microphone.
5 farklı kişi bu kılavuzu tamamladı.
nat coll
508 İtibar
14 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
Can you change the grilles of sm58 and sm86?
Jack - Yanıt
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 47
Her zaman: 7,571
