Ana içeriğe geç
Side Panel Removal
Neye ihtiyacın var
  1. Side Panel Removal, Side Panel Removal: adım 1, 3 resimden 1. Side Panel Removal, Side Panel Removal: adım 1, 3 resimden 2. Side Panel Removal, Side Panel Removal: adım 1, 3 resimden 3.
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. Side Panel Removal: adım 2, 3 resimden 1. Side Panel Removal: adım 2, 3 resimden 2. Side Panel Removal: adım 2, 3 resimden 3.
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Oli
1.523 İtibar
4 adet Kılavuz yazıldı
1Rehber Yorum
I took it out, but now it’s not going all the way in
Ali - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 52
Son 30 gün: 91
Her zaman: 3,260
