Ana içeriğe geç
Sidekick II Battery Replacement
Neye ihtiyacın var
    1. Sidekick II Battery Replacement, Outer Casing: adım 1, 1 resimden 1.
      • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
      • Gently pry open button and remove button.
      • Do this for each of the 3 buttons remaining.
      FixBot'a Sor
      Yorum Ekle
    2. Sidekick II Battery Replacement: adım 2, 2 resimden 1. Sidekick II Battery Replacement: adım 2, 2 resimden 2.
      • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
      FixBot'a Sor
      Yorum Ekle
    3. Sidekick II Battery Replacement: adım 3, 1 resimden 1.
      • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
      FixBot'a Sor
      Yorum Ekle
    4. Sidekick II Battery Replacement: adım 4, 1 resimden 1.
      • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
      • Use the Torx 6 screwdriver to remove these 2 screws.
      • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
      FixBot'a Sor
      Yorum Ekle
    5. Sidekick II Battery Replacement: adım 5, 1 resimden 1.
      • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
      • You can use your hands to simply pull apart the top casing from the bottom casing.
      FixBot'a Sor
      Yorum Ekle
    1. Sidekick II Battery Replacement, Battery: adım 6, 1 resimden 1.
      • Remove the 5 screws using the Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sidekick II Battery Replacement: adım 7, 1 resimden 1.
      • Separate control board from housing using your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. Sidekick II Battery Replacement: adım 8, 1 resimden 1.
      • Lightly pry upward on battery and back plate, and remove.
      • Do not use metal tool to pry. Use your fingers.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
michael albaum
108 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G19
4 Üyeler
60 adet Kılavuz yazıldı
3Kılavuz Yorumları
I have the battery out. Is their a way to check if it holds a charge? when I plugged charger into sidekick nothing lit up? is it a battery problem or a charge issue? The phone was never damaged. like the rest stop using it so died. figured battery is toast. this was a replacement tutorial. but doesn't show new battery going in to make sure you did correctly. I need the text messages and other data from my phone pretty bad. any help greatly appreciated.
Kyle Wilkins - Yanıt Paylaş
Hi, I don’t have any Sidekick-specific advice here, but some for general data recovery from old phones like these. What I’ve done in the past is hunt down another donor phone that is functional, with a working charger, and use it to diagnose the issues on your phone, and make a working model with your motherboard.
Dylan McLaughlin - Yanıt Paylaş
Thank you for doing this guide! Six years later, it helped me replace the battery in my Sidekick so I could boot it up again for some nostalgia. I’ve missed the dead battery noise ;)
Booksavvy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 68
Her zaman: 7,700
