Ana içeriğe geç
Sidekick II LCD Screen Replacement
Neye ihtiyacın var
    1. Sidekick II LCD Screen Replacement, Outer Casing: adım 1, 1 resimden 1.
      • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
      • Gently pry open button and remove button.
      • Do this for each of the 3 buttons remaining.
      FixBot'a Sor
      Yorum Ekle
    2. Sidekick II LCD Screen Replacement: adım 2, 2 resimden 1. Sidekick II LCD Screen Replacement: adım 2, 2 resimden 2.
      • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
      FixBot'a Sor
      Yorum Ekle
    3. Sidekick II LCD Screen Replacement: adım 3, 1 resimden 1.
      • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
      FixBot'a Sor
      Yorum Ekle
    4. Sidekick II LCD Screen Replacement: adım 4, 1 resimden 1.
      • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
      • Use the Torx 6 screwdriver to remove these 2 screws.
      • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
      FixBot'a Sor
      Yorum Ekle
    5. Sidekick II LCD Screen Replacement: adım 5, 1 resimden 1.
      • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
      • You can use your hands to simply pull apart the top casing from the bottom casing.
      FixBot'a Sor
      Yorum Ekle
    1. Sidekick II LCD Screen Replacement, LCD Screen: adım 6, 2 resimden 1. Sidekick II LCD Screen Replacement, LCD Screen: adım 6, 2 resimden 2.
      • Flip the screen to its up position.
      • Remove screen from keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. Sidekick II LCD Screen Replacement: adım 7, 1 resimden 1.
      • Remove 4 screws from back of screen.
      FixBot'a Sor
      Yorum Ekle
    3. Sidekick II LCD Screen Replacement: adım 8, 1 resimden 1.
      • Separate screen from housing with your fingers.
      FixBot'a Sor
      Yorum Ekle
    4. Sidekick II LCD Screen Replacement: adım 9, 3 resimden 1. Sidekick II LCD Screen Replacement: adım 9, 3 resimden 2. Sidekick II LCD Screen Replacement: adım 9, 3 resimden 3.
      • Remove 4 screws
      • Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
      FixBot'a Sor
      Yorum Ekle
    5. Sidekick II LCD Screen Replacement: adım 10, 1 resimden 1.
      • Remove LCD protective cover with your fingers.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
michael albaum
108 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G19
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 4,301
