Ana içeriğe geç
Sidekick II Thumbwheel Replacement
Neye ihtiyacın var
  1. Sidekick II Thumbwheel Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Thumbwheel Replacement: adım 2, 2 resimden 1. Sidekick II Thumbwheel Replacement: adım 2, 2 resimden 2.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Thumbwheel Replacement: adım 3, 1 resimden 1.
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Thumbwheel Replacement: adım 4, 1 resimden 1.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Thumbwheel Replacement: adım 5, 1 resimden 1.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Thumbwheel Replacement, Thumbwheel: adım 6, 1 resimden 1.
    • Remove 2 screws using the Torx 6 screwdriver.
  7. Sidekick II Thumbwheel Replacement: adım 7, 1 resimden 1.
    • The thumbwheel and casing will be loose, gently remove it.
Bitiş Çizgisi
michael albaum
87 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G19
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,152
