Ana içeriğe geç
Siemens A56 Clean Charging Port Replacement
Neye ihtiyacın var
  1. Siemens A56 Clean Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Clean Charging Port Replacement: adım 2, 1 resimden 1.
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Clean Charging Port Replacement, Clean Charging Port: adım 3, 1 resimden 1.
    • Use soft brush to clean the charging port of the phone. If needed, use alcohol and a q-tip for more thorough cleaning.
Bitiş Çizgisi
Lauren Young
322 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G6
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 253
