Ana içeriğe geç
Siemens A56 Keyboard Replacement
  1. Siemens A56 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
    FixBot'a Sor
    Yorum Ekle
  2. Siemens A56 Keyboard Replacement: adım 2, 1 resimden 1.
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Siemens A56 Keyboard Replacement, Front Plate: adım 3, 3 resimden 1. Siemens A56 Keyboard Replacement, Front Plate: adım 3, 3 resimden 2. Siemens A56 Keyboard Replacement, Front Plate: adım 3, 3 resimden 3.
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Siemens A56 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Siemens A56 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Siemens A56 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • The keyboard can be easily removed by hand.
    • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Andrew Corriveau
97 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G6
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 640
