Giriş
These instructions show how to remove the back panel. First, the side panel on the water tank must be removed.
''These instructions can also be used with other Siemens/Bosch models - the models have a similar structure.
Neye ihtiyacın var
Remove all attachments such as water tank, pulp drawer, brew group.
Remove the coffee container lid and take out all the coffee beans.
Lay the machine on its side with the water tank side facing up.
The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
The rear panel is removed in a similar way to the side panel. To do this, lay the machine on its side with the floor facing you.
Use a powerful pry tool to loosen the three strong latches on the floor.
Put the machine back upright so the back is facing you
The back is locked in place like a bayonet with three locking lugs on the left. Lift the top up about 5mm and slide the back up about 5mm, it'll probably pinch a lot the first time. Then you can take them off.
Follow the steps in reversed order to reassemble your device
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
