Giriş
The gaskets of the brewing unit are heavily used and should be replaced from time to time.
This brewing unit is identical to units of other brands, e.g. Nivona, Bosch, Melitta. Note: the pictures show the newer version of the brewing unit with the large release lever. There are hardly any differences for the repair.
Neye ihtiyacın var
Remove all attachments such as water reservoir, coffee compartment lid, trester drawer.
Remove all coffee beans from the bean hopper.
Open the side flap.
Loosen the three rubber caps on the brew group.
Using a strong flat-blade screwdriver, adjust the three plastic slots underneath so that the "unlocked" position is indicated.
Pull out the brew group. If it is stuck, pull firmly and evenly, but with feeling, preferably at the bottom right.
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
To reassemble your device, follow these directions in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
