Neye ihtiyacın var
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
Turn the coffee maker so the side panel faces you.
Press the two plastic expansion rivets together with pliers and push them out.
Turn the side panel over again
Lift the cap over the gasket.
Remove the seal.
To reassemble your device, follow the steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Where can I find a part-list for the seals etc? I am worried im am missing a seal. I also saw a video of usage of food grade grease I am willing to try.
In germany for example https://www.juraprofi.de/ or www.komtra.de. Ask them, if they ship to your country.
VauWeh -
