Ana içeriğe geç
Siemens-Maquet Servo-i Bacteria Filter Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Siemens-Maquet Servo-i Bacteria Filter Replacement, Filter for Gas Modules: adım 1, 1 resimden 1.
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Bacteria Filter Replacement: adım 2, 1 resimden 1.
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Bacteria Filter Replacement: adım 3, 1 resimden 1.
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Bacteria Filter Replacement: adım 4, 1 resimden 1.
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Bacteria Filter Replacement, Bacteria Filter for O2 Cell: adım 5, 1 resimden 1.
    • Twist off white filter cap.
    • Service Manual 7 - 4
    • Use the Maintenance kit, 5,000 hours to replace the bacteria filter for the O2 cell.
Sonuç
rachel davis
110 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020 üyesi
CPSU-ZIMMERMAN-S20S1G2
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 416
