Ana içeriğe geç
Giriş
1°/ Remove the 4 screws on the bottom (take care because to one, the blue screw, of them is shorter than others).
Parçalar
Hiçbir parça belirtilmedi.
  1. 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
    • 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  3. Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
    • Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
  4. Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
    • Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Greg
349 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 14
Her zaman: 2,489
