Ana içeriğe geç
Signode BXT3-16 Strapping Combo Tool Spring Replacement
Neye ihtiyacın var
  1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: adım 1, 1 resimden 1.
    • Before dismantling the strapping gun, ensure the power source / battery is removed.
  2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 2, 1 resimden 1.
    • Turn the strapping gun upside down.
    • Place it on a flat surface to keep the strapping gun stable during repair.
    • There are four Torx T4 screws on the bottom of the tool.
  3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 3, 3 resimden 1. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 3, 3 resimden 2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 3, 3 resimden 3.
    • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
    • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
    • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
  4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 4, 1 resimden 1.
    • Rotate the strapping gun to the opposite side.
    • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
  5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 5, 2 resimden 1. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 5, 2 resimden 2.
    • Rotate the strapping tool to the original position, with the model number and name facing you.
    • Firmly pull the guard plate and the tool apart using both hands.
  6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 6, 2 resimden 1. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 6, 2 resimden 2.
    • Use a metal spudger to lift the cutter.
    • Gently, push the spring out from the bottom of the base of the strapping gun.
  7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 7, 3 resimden 1. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 7, 3 resimden 2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: adım 7, 3 resimden 3.
    • Rotate the machine to remove the spring gently by hand.
    • Remove the spring from the base of the strapping tool.
    • Replace with new spring by inserting it the same way it was removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jainam Shah
172 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 844
