Ana içeriğe geç
Simple Fix For Stuck Power / Cancel Button
Neye ihtiyacın var
  1. Simple Fix For Stuck Power / Cancel Button, Identify the Model / Safety Precaution: adım 1, 1 resimden 1.
    • Identify your washer type. The Power / Cancel button may differ with different models. This was my model tag.
    • On my unit the model number tag was found by opening the washing machine door.
    • ** WARNING ** - UNPLUG POWER PRIOR TO WORKING. YOU WORK AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR YOUR SAFETY!
  2. Simple Fix For Stuck Power / Cancel Button, Locate the Power / Cancel Button: adım 2, 1 resimden 1.
    • The power button contains a gray colored round button actuator in a chrome housing. The words "Power - Cancel" (solid dot between words) are printed above the button
    • Apparently the stuck button was actually caused by the chrome housing/ring being pressed in too far at the bottom or otherwise misaligned. This was not a problem with the actuator itself as I first thought.
  3. Simple Fix For Stuck Power / Cancel Button, Release the button housing: adım 3, 1 resimden 1.
    • The simple fix here was to take a metal pick (or other thin but firm tool) and carefully get under the chrome housing (ring) at the bottom and wedge it up or slightly forward.
    • To my surprise there was a slight click/pop that indicated the housing ring was released.
    • Plug the washing machine back into the power source and lightly touch the Power / Cancel button actuator.
    • My advice to avoid this in the future is to more carefully "touch" the center of the gray actuator with minimal force rather then "mash" the whole button during use.
    This saved us. Although we have a different model.
    Haitham - Yanıt
    Thank you! I used a dental pick and it popped right back in place.
    Kim Hunt - Yanıt
    This worked on a machine, using the tweezers from a Swiss Army knife. Thanks for the suggestion.
    cbk - Yanıt
    Great to hear!
    drmdolfan -
    I tried this but it ended up pushing button way out of place
    shayla fiddler - Yanıt
    Yeah you have to be especially careful and only use slight pressure.
    drmdolfan -
    used a dental pick also and it worked, thanks for the guidance.
    Dennis Duggan - Yanıt
    Great to hear!
    drmdolfan -
    Thank you for your advice!! It worked like a charm!!
    Alisha Boyce - Yanıt
    It worked using a flat flexible blade and a bottle opener
    Paul Allen - Yanıt
    Hello, I have a Maytag 4000 series and the Power/Cancel button seems to not be working all of a sudden. I tried to unplug it and then when I plugged it back in I heard a pop and it worked when I pressed the button. But it seems to work on and off. Does anyone have a clue what it could be? if it's something simple I don't want a tech to come out charge me $118.00 that is a simple fix. Please help I am a widow and need help with this. Thank you in advance. Model # MHWE450WW01 ALSO SERIAL CS00804203 4.5 CU FT. You can also email me at kachia4@aol.com Thank you
    kachia4 - Yanıt
    Would anyone know where to purchase a replacement button and ring?
    Wayne Vallier - Yanıt
    This totally did the trick. No repair bill needed. Thank you for your post!
    Judy Smith - Yanıt
    Great! So glad to help.
    drmdolfan -
    It worked for me, thank you so much!
    Candice Palmer - Yanıt
    So happy to hear that it worked for you!
    drmdolfan -
    The power button on our Maytag 3000 has been off center and loose for a while. My wife had a special techique, pushing gently around the 1 o’clock position and that worked. Today, wife my wife out of town, I pushed this button too hard and it no longer worked. I took the top off and removed the control panel to find that the other end of this button is a 1.5 inch long piece of thin plastic that pushes a small red switch inside the control panel. This button is held in place by thin metal and other plastic pieces. Not made well enough to last as long as the working parts of this washer.
    I removed the power button (actually it fell out in pieces), put the machine back to together and used a 3 inch piece of plastic irrigation tubing to reach the red activator button inside the machine and it powers on and off much easier than fussing with a dysfunction plastic part. I am not recommending anyone else try this, but seems to work for me so far. Obviously I will only use plastic -non conductor of electricity.
    Maytag McGiver - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
drmdolfan
2.759 İtibar
6 adet Kılavuz yazıldı
Ekip
CSRA Fixers CSRA Fixers üyesi
Community
1 Üye
10 adet Kılavuz yazıldı
8 Yorum
Hello I have a GE front loader and my power went out before it was done it had a minute to go and now it does not want to start back up what do I do and I thought I would unplugged it for a hour thinking it would reset it self but that didn't work
Margaret Greene - Yanıt
There are some things which can cause this - online they talk about a stuck water valve or a door switch problem. Make sure to completely restart a cycle. There is also a reset process where you unplug the power cord and then hold down the power button for at least 5 seconds after plugging the power cord back in.
drmdolfan - Yanıt
Can this be done with a Maytag 4000 series same as the picture from this post. I changed the sensor and cleared all tubes of debris and cleaned the back filter to the tub and took out some plastic, also cleaned out the filter at the bottom connected to the water pump. I’ve done it all and I’m still getting the F32 and F20 code, the F 32 doesn’t stay on anymore but it stops the washing process. I’m thinking memory code has to be reset and I can’t find out how. Help!
Lonestar llama -
Thank you so much, saved me a lot of money and hassle.
kanonarose - Yanıt
Pleased to help
drmdolfan - Yanıt
I replaced my control board on my Frigidaire washers and I'm getting key stuck message pop up on my screen around two minutes after I turn it on
Calvin King - Yanıt
Thank you! Worked as predicted! 5 seconds! Took me longer to find a “tool” than to fix it!
teresa - Yanıt
This is a great tip, but unfortunately, in my case, the housing ring was actually broken and there is absolutely no way to get a replacement part. I have called everywhere. So for the want of a 10c piece of plastic I need to replace a perfectly good Maytag Washing machine. Very sad. So much for sustainable and reusable!
John Davies - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 140
Son 30 gün: 604
Her zaman: 58,147
