Ana içeriğe geç
Singing Machine Shine Duets Audio/Power Jack Replacement
Neye ihtiyacın var
  1. Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 2. Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 3.
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 2, 3 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 2, 3 resimden 2. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 2, 3 resimden 3.
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 3, 3 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 3, 3 resimden 2. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 3, 3 resimden 3.
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets Audio/Power Jack Replacement, Motherboard: adım 4, 1 resimden 1.
    • The motherboard is located right behind the control buttons.
  5. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 5, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 5, 2 resimden 2.
    • Remove the two screws holding the LED board in place.
  6. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 6, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 6, 2 resimden 2.
    • Remove both LED boards from their pins.
  7. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 7, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 7, 2 resimden 2.
    • Detach the white cable from its connector on the motherboard.
  8. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 8, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 8, 2 resimden 2.
    • Carefully disconnect this red-and-black wire from the motherboard.
  9. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 9, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 9, 2 resimden 2.
    • Remove the thicker red-and-black wire from its socket on the motherboard.
  10. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 10, 3 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 10, 3 resimden 2. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 10, 3 resimden 3.
    • Disconnect the red port on the board which holds all of the external plugs
    • Disconnect the white wires from the board.
  11. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 11, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 11, 2 resimden 2.
    • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
  12. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 12, 3 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 12, 3 resimden 2. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 12, 3 resimden 3.
    • Remove the motherboard from the shell.
  13. Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: adım 13, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: adım 13, 2 resimden 2.
    • Remove both screws from the board.
    • Use caution when removing the screw in between the two ports.
  14. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 14, 2 resimden 1. Singing Machine Shine Duets Audio/Power Jack Replacement: adım 14, 2 resimden 2.
    • Remove the board from the shell.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 56
Her zaman: 554
