Ana içeriğe geç
Singing Machine Shine Duets LED Lights Replacement
Neye ihtiyacın var
  1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 2. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: adım 1, 3 resimden 3.
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets LED Lights Replacement: adım 2, 3 resimden 1. Singing Machine Shine Duets LED Lights Replacement: adım 2, 3 resimden 2. Singing Machine Shine Duets LED Lights Replacement: adım 2, 3 resimden 3.
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets LED Lights Replacement: adım 3, 3 resimden 1. Singing Machine Shine Duets LED Lights Replacement: adım 3, 3 resimden 2. Singing Machine Shine Duets LED Lights Replacement: adım 3, 3 resimden 3.
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets LED Lights Replacement, LED Lights: adım 4, 3 resimden 1. Singing Machine Shine Duets LED Lights Replacement, LED Lights: adım 4, 3 resimden 2. Singing Machine Shine Duets LED Lights Replacement, LED Lights: adım 4, 3 resimden 3.
    • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
  5. Singing Machine Shine Duets LED Lights Replacement: adım 5, 3 resimden 1. Singing Machine Shine Duets LED Lights Replacement: adım 5, 3 resimden 2. Singing Machine Shine Duets LED Lights Replacement: adım 5, 3 resimden 3.
    • Carefully remove the lightboard from the device, taking care not to damage any pins.
    • To reassemble, connect the pins on the lightboard to the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 75
