Giriş
If you are having issues with a water leak under your sink, but it is not due to your plumbing connections or the faucet itself, then you may have an issue with your water supply lines. These supply lines are the connections between your water valves and your sink faucet. Over time, these supply lines can wear out, especially around the connections.
This guide will show you everything you need to do to replace your water supply lines in the most efficient way possible in an easy to follow, step-by-step format. Replacing water supply lines does not require any special skills to complete, and should not take any more than an hour, even if it is your first time doing this replacement!
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Clear the cabinet of any items to provide adequate workspace.
Place a towel down under the supply lines to absorb any dripping water.
Once the new water supply line is placed and properly fastened, the water valve can be switched back on.
Grab the water valve and rotate it to the open position, which is typically in parallel to the water line, in contrast to earlier where a valve in the off position was perpendicular to the water line.
To ensure no leaks arise from your newly connected water supply lines, proper practice would be to turn on the water faucet and check both connections to ensure no water is dripping or leaking out.
If no water is seen leaking from your line or your connections, then you have successfully replaced your old water supply line!
Should you need to replace the other water supply line under your sink, the same process can be used for both supply lines.
The process for reassembling the water line is included in the guide as it is a crucial component of the guide. Should you need to replace both water supply lines, then simply follow the same guide steps for the other line.
Bir başkası bu kılavuzu tamamladı.
