Ana içeriğe geç
Sink O-Ring Replacement
Neye ihtiyacın var
  1. Sink O-Ring Replacement, O-Ring: adım 1, 1 resimden 1.
    • Locate both valves for hot and cold water. These are typically under the sink.
    • Turn off the water supply by turning each knob clockwise to stop the flow of water.
  2. Sink O-Ring Replacement: adım 2, 1 resimden 1.
    • Put on gloves, as mold might be present.
  3. Sink O-Ring Replacement: adım 3, 1 resimden 1.
    • Locate the screw insert in the sink handle.
  4. Sink O-Ring Replacement: adım 4, 1 resimden 1.
    • Take out your screwdriver and attach the appropriate bit for your screw.
  5. Sink O-Ring Replacement: adım 5, 1 resimden 1.
    • Insert the screwdriver into the screw in the sink handle, and rotate the screwdriver counterclockwise (left) to remove the screw.
  6. Sink O-Ring Replacement: adım 6, 1 resimden 1.
    • Gently, but firmly, pull out the sink handle once the screw is removed.
  7. Sink O-Ring Replacement: adım 7, 2 resimden 1. Sink O-Ring Replacement: adım 7, 2 resimden 2.
    • Once the handle is separated from the sink, clean it and its interior with an antibacterial spray, such as Lysol or Clorox.
    • If the sink has been linked for some time, mold has likely accumulated.
  8. Sink O-Ring Replacement: adım 8, 1 resimden 1.
    • Remove the screw at the top of the O-ring.
    • If mold is present, clean the screw with disinfectant.
  9. Sink O-Ring Replacement: adım 9, 1 resimden 1.
    • Using an adjustable wrench, remove the O-ring.
  10. Sink O-Ring Replacement: adım 10, 1 resimden 1.
    • Replace the old O-ring with the new one.
  11. Sink O-Ring Replacement: adım 11, 1 resimden 1.
    • Re-assemble the sink, reversing all steps used to disassemble the sink.
    • Congratulations! Once all the steps have been reversed and completed, feel free to test out your updated sink.
Bitiş Çizgisi
Brooke Don
193 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-8, Vidal-Chiesa Fall 2024 UC Davis, Team 2-8, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S2G8
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 116
