Ana içeriğe geç
Sirius Stiletto 2 Front Cover Replacement
Neye ihtiyacın var
  1. Sirius Stiletto 2 Front Cover Replacement, Battery: adım 1, 1 resimden 1.
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 Front Cover Replacement: adım 2, 2 resimden 1. Sirius Stiletto 2 Front Cover Replacement: adım 2, 2 resimden 2.
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 Front Cover Replacement, Front Cover: adım 3, 1 resimden 1.
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 Front Cover Replacement: adım 4, 2 resimden 1. Sirius Stiletto 2 Front Cover Replacement: adım 4, 2 resimden 2.
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
Sonuç
Benjamin Her
555 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Brown Winter 2015 USF Tampa, Team 6-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 277
