Ana içeriğe geç
Sirius Stiletto 2 Scroll Wheel Replacement
Neye ihtiyacın var
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Battery: adım 1, 1 resimden 1.
      • From the back of the device, slide the back panel downwards to unlock the panel.
      • Lift the panel up, exposing the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Sirius Stiletto 2 Scroll Wheel Replacement: adım 2, 2 resimden 1. Sirius Stiletto 2 Scroll Wheel Replacement: adım 2, 2 resimden 2.
      • Pinch the battery from both sides and lift the battery to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Front Cover: adım 3, 1 resimden 1.
      • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
      • If needed, remove the sticker to see the screws
      FixBot'a Sor
      Yorum Ekle
    2. Sirius Stiletto 2 Scroll Wheel Replacement: adım 4, 2 resimden 1. Sirius Stiletto 2 Scroll Wheel Replacement: adım 4, 2 resimden 2.
      • Start by using a plastic opening tool to loosen the front cover from the sides.
      • Work your way to the bottom of the cover then the top.
      • Carefully pry the front cover off.
      FixBot'a Sor
      Yorum Ekle
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: adım 5, 2 resimden 1. Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: adım 5, 2 resimden 2.
      • Isolate the scroll wheel assembly
      • Gently pry the four metal tabs outwards, away from the scroll pad.
      FixBot'a Sor
      Yorum Ekle
    2. Sirius Stiletto 2 Scroll Wheel Replacement: adım 6, 1 resimden 1.
      • Once the scroll pad has been released, be careful not to drop the center button. This may damage the spring.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Her
567 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Brown Winter 2015 USF Tampa, Team 6-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 570
